Any ideas on tilt switches...
I have been Googling around the internet for tilt switchs.· There is alot out there, but some are very expensive, and others are only $.95, but the company has a $20 minimum order.· I have tried to homebrew a couple of different types, using a rolling ball in a tube to activate a snap switch, but there is just to much friction on the ball to detect low angles of tilt.· (Plus or minus 10 to 15 degrees of tilt)
Does anyone have a source for good tilt switchs that are reasonally priced and I don't have to buy 20 of them to meet the minimum order.·
Or...perhaps, someone has a better idea then I had for a homebrew tilt switch.· All I want to do is detect slope to either apply braking action, or more power to go up hill using two tilt switches.
The Mimsic 2125 that is sold by Parallax is a good device, but upon acceleration, the device shows to much G force, thus producing a false slope reading.· It's just to senseitive to be usful here.
Deno
Deno
'Still some PropSTICK Kit bare PCBs left!
On the other hand, or going up hill, of 10 degrees or more, I would like to "shift gears" and apply more power (PWM) to the HB25.
As mentioned in the above post, the 2125 is just to sensitive.· By the time I increase the offset to a point where the 2125 won't take action (speed ramping up by the HB25), I am up to about 20 degrees of tilt. A mercury switch would probably work well because the mercury itself is heavy, but I just wanted to get some input form some others who might have experience the same problem in Robotics.
Deno
Post Edited (deno) : 8/22/2008 8:19:38 PM GMT
"A mercury switch would probably work well because the mercury itself is heavy" - You will still have the inertia that Phil was describing acting on the mercury or whatever... It doesn't really matter that it's heavy or not.
To determine tilt from an accelerometer, you also need to know how fast you are going.· So some sort of wheel encoder to monitor ground·travel.
speed = delta Distance / delta time
acceleration = delta speed / delta time
Tilt = accelerometer·- acceleration
Beau Schwabe
IC Layout Engineer
http://www.scmstore.com/english/sensor/highQuality/data/CW/1300/
However I had to buy 100 of them about a buck each.
PM me for my address and you can send me 4 bucks and a sase for 2 of them.
If you put 4 on a board you can get a nice tilt sensor. by putting the angle of each a tad higher in the center you can make it more sensitive. I have used them for on off switches for battery operated devices where you turn it upside down to activate it or shake it to make it turn on etc... lots of fun things you can do with them. I still have 94 of them in the bag.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (metron9) : 8/23/2008 3:37:07 AM GMT
I would think that a method like this could work quite well for you and be fairly easy to home-brew.
Hope this helps,
Tim
I dont see a pendulum working well at all, it would give you the same problems as the accelleromoeter, and every time you hit a bump it would move, and the allready noted swinging when you stop.
I dont know what scale you are working at,Maybe by usuing to pieces of wire and a heavier ball (like a pinball)·you might overcome the friction problems of using a tube type track, the wire would have less friction and less surface area.
Deno
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16165
Here is one more to look I bought some these they work but you have go little more than 0* to 110* degrees to tilt them
··Thanks for any·
Sam
