Propeller 10Mbps Ethernet Challenge — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2008-08-21 21:54 in Propeller 1
Would it be at all possible for a Propeller COG running PASM to transmit/receive buffered Ethernet frames on propeller pins at 10Mbps? Maybe one direction per COG? Maybe using multiple COGS? See this link for Ethernet link layer definition: http://en.wikipedia.org/wiki/Ethernet#Physical_layer
I don't really have time to follow through on trying this. Maybe others do?
--Steve
    edited 2008-08-21 20:46
    This has come up before — for transmission anyway. See this thread. Reception will be much harder.
    'Still some PropSTICK Kit bare PCBs left!
  • jazzedjazzed Posts: 11,803
    edited 2008-08-21 20:57
    Thanks Phil. Saw code posted from Hippy. I'll poke around when I have more time. So TX worked, but RX was not possible/reliable?
    --Steve
    edited 2008-08-21 21:02
    Steve,
    My Manchester output routine (page 2) kinda worked. There may still be an open issue regarding the phase of the chroma counter. (It's been awhile.) I don't know if anyone's attempted RX yet.
  • hippyhippy Posts: 1,981
    The raw bit stream is probably too fast (20Mbps) to be decoded by bit-banging on a single cog, but if it could be de-Manchester Encoded, then clocked into a shift register it would drop to just 1.25MBps which could be manageable, at least to get bytes into the Propeller for subsequent decoding.
