Is it safe?
Hi All,
···· I have converted a old power supply from a desktop computer·I had laying around to be used for powering my projects. My question is... Is it safe to connect a Board of Education to 12 Volts on the power supply. My thinking for this power supply is it has 3.3V, 5V and 12V basicly all the voltage I should need.
When you spend 10 times what it cost to build it yourself - That's when it becomes a HOBBY !
The regulator on the Board of Education and the one on the Stamp module itself all have datasheets that you can easily download and these give the upper limit of the input voltage for the regulator. You'll find that both of them can easily tolerate +12V and quite a bit higher. They do have to dissipate any excess voltage as heat proportional to the current drain. The regulator on the Stamp module is intended to supply up to 50mA and the one on the BOE is intended to supply up to 1A. The higher the input voltage, the more heat has to be dissipated. With a 12V input and a 1A current drain, you're dissipating (12V - 5V = 7V) x 1A = 7W which would make the BOE regulator quite warm. It has a small heatsink, so that'll help. Most regulators will shut down if they get too hot, so you wouldn't damage them, but the BOE might stop working until things cool off.
·· This is a link that is used: http://web2.murraystate.edu/andy.batts/ps/powersupply.htm I just thought from what I saw this would make a idel power supply for robotic projects.
I didn't say it wouldn't work. I just don't know whether it will or whether it will blow something. If you read the article you referenced in the link, there are some caveats. There's a minimum load provided. You have to check the result to make sure it works as expected before you hook up something expensive or hard to replace to it. You probably should fuse everything since there's often not much difference between a PC power supply and a small arc welder. Other people have done successfully what you would like to do, but some people I'm sure have ended up with a small boat anchor.
Carry out the mods in the article and then do a load (regulation) test.··From that point you could decide to use it just for your motors.·
12V may be pushing the envelope for use as BoE/HWB "Vin".· There may be a trim-pot in the 'ATX' that you could tweak to adjust that somewhat lower.
