CMUcam1 usage (Still Waiting a Solution)
Can i use CMUcam1 along with all assessories like ping, IR headlights, photoresistors, QTI LINE Follower, gripper, whiskers·on Boe-Bot. Actually i have all these assessories.
Post Edited (Shy) : 8/22/2008 4:19:53 PM GMT
It's a modified version of the CMUcam, mostly so it can attach directly to the BoeBot's AppMod connector. There's sample code included on the webstore page.
There are 16 I/O pins on the Stamp. Each of the accessories you mention need one or more I/O pins. You have to add it all up and see if you run out. There are ways to expand the I/O capability of a Stamp (check out the Basic Analog and Digital tutorial), but it's not like just adding I/O pins. For example, the various built-in I/O statements (like PULSOUT, PULSIN, COUNT, SERIN, SEROUT) can only be used with the built-in I/O pins.
One more thing to mention i use all the I/O pins of stamps by my choice. e.g i connect the ping to PIN0, and ping servo to PIN1 etc. Does it matter?
but when i use that CMUcam on other boe-bot with no accessories, it works fine.
Please clear me one thing whether CUMcam1 can work with all the pins (16) of stamp in use??
You state the you have other (many other?) devices connected, maybe all that's dragging down your supply voltage.
You asked... "Please clear me one thing whether CUMcam1 can work with all the pins (16) of stamp in use??"
Hope you aren't "sharing" inputs or outputs.
- Stephen
