SD and demoboard
I've built a sd connector·following·the jeff ledger propeller cookbook, ·using p0..p3 and·I used·fsrw & friends files to check it..
The program returns values·between ·254· and·127 .. differents values but always positive..
Any ideas?
thanks.
Any ideas?
thanks.
Any indications on whether it's failing during mount, open, read, or what? Do you have
an oscilloscope? What size SD card are you using, and how did you format it?
I use a 32mb SD formatted fat16 cluster 4096·or windows xp standard clusters always fat 16.
I've not plugged resistors as in the propeller cookbook example..
Wrong sd card..
thanks.
