Storing PIN into variable?
I have BS2e connected to several sensors of the same kind.
So, I want to use subroutines and select sensor before calling.
Something like this:
sensor1·CON 0
sensor2 CON 1
selectedsensor VAR Nib
selectedsensor = sensor1
getData
selectedsensor = sensor2
getData
getData:
PULSIN selectedsensor,0,Var
RETURN
According to documentation all commands taking 'Pin' can use variable as input, but the above does not work
I've tried to use PIN also, but no change!
What is the best way to solve this problem?
sensor1·CON 0
sensor2 CON 1
getData
getData
getData:
RETURN
I can not get it to work!
I will do some more debugging!
Post Edited (mgrey) : 8/19/2008 6:04:54 PM GMT
The problem was that at one part of the code there was a check if a pin went low like:
DO:
LOOP WHILE sensor
this worked when sensor was defined as PIN, but of course not as CON
I solved it by:
DO
IF sensor = 0 THEN
sensorin = IN0
ENDIF
IF sensor = 2 THEN
sensorin = IN2
ENDIF
LOOP WHILE sensorin
It works but it is not so nice code!
