New to BASIC Stamp - Need Help
Hi there,
I'm a 5th form student at Sacred Heart College, in New Zealand and am currently taking electronics as a subject.
My main assignment this year is "to extend the use of an existing technology"
My existing technology is the Vmusic2 module and i choose to extend it by designing and building an aircraft data logger that will record (so far) g force on 3 axis, temperature, humidity and possibly altitude. i am using a Picaxe 28X1 for the main microcontroler.
I ordered two sensors from parallax, the Hitachi H48C Tri-Axis Accelerometer Module and the Sensirion Temperature/Humidity Sensor.
Both of these sensors use the SHIFTIN/OUT commands which are an absolute nightmare to use on the picaxe so after weeks of messing around on the pixace forum and futile attempts at bit bashing i am seriously considering ordering a BASIC Stamp module because, as i understand, the source code can be downloaded for each sensor and dropped straight into the programmer without any modification to the code - apart from subbing in the appropriate pin numbers - is this correct?
I am really sick of getting nitty-gritty with code and just want to get the sensors going in as little time as possible (i have to hand this in soon)
What is the CHEAPEST stamp setup that would work with these sensors.
I already have lots of breadboards, components (resistors, capacitors etc.. ) a seriall programming cable and everything else.
Can you program the stamp without another development/programming board?
Any help would be greatly appreaciated.
SHIFTIN/SHIFTOUT commands are available for any of the BS2 series, though not for the BS1. That means you can go with whichever of the BS2 microcontrollers suits your needs. A regular BS2 goes for $49 - some of the faster/more memory versions are only a few dollars more, though. A low-end carrier board (which you will also need) goes $16, though I'd spend the extra $4 for the "super carrier board".
When you have that, all you need is a standard serial cable, as long as your computer has a regular old DB-9 style serial port. If you only have USB ports, you'll need the $20 USB/Serial converter.
With the BS2 and the sample code, you should have no problem reading those sensors within just a few minutes of getting set up. I have a nice little setup on a BS2 connected to the Sensiron Temp/Humidity device, sending the readings out through an XBee Pro to be received by another XBee connected to·a computer through a Prop Plug. Works like a charm.
Post Edited (sylvie369) : 8/19/2008 11:13:22 AM GMT
After 6 years of primary school you start intermediate, which is from year 7 to 8.
at year 9, you start college (highschool) and college goes from year 9 to 13.
Year 9 is form 1, year 10 is form 2 etc all the way up to form 7 which is year 13, after that you start university.
would the BASIC Stamp 2 OEM Module (Kit Form) be alright with my sensors?
http://parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/CategoryID/12/List/0/SortField/0/Level/a/ProductID/121/Default.aspx
http://parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/CategoryID/12/List/0/SortField/0/Level/a/ProductID/122/Default.aspx
However, yes, the absolute cheapest way to go is the OEM module. My recomendation: If you can solder and are going to use the BS2 as a slave, use the OEM. If you are going to use the BS2 as a master, use the standard module.
So, in NZ required schooling lasts for 14 years? In the states its only 13... (with kindergarten)
I don't really wanna use a carrier board because that means that i have to permanently solder the sensor to the board. i have the parts for a serial download circuit i ill most probably get the basic stamp 2sx module sine the normal basic stamp 2 is out of stock.
I am still contemplating the oem module as it includes the full download circuit in the module. how hard is the normal basic stamp 2 module to program in terms of the download circuit?
Abut the school thing, NZ is pretty much the same as the states and school only lasts 13 years, with the 13th year being an option.
I've built a couple of the OEM kits, and while I did find the closely spaced transistors and "reset supervisor" a bit of a challenge, they all worked fine without too much trouble. Make sure you have a good soldering iron and some kind of lighted magnifier to inspect your work carefully.
E-Source Ltd.
Auckland
Phone: Intl: +64211929950
Fax: Intl +64 9 521 3832
Web: http://www.basicstamps.co.nz/
Email: sales@esource.co.nz
Thanks alot for all the helpful information
Ronald Nollet [noparse][[/noparse]ron@nollet.com.au]
I know some people who wished that the 13th year was an option... Some teachers too...
My Economics teacher liked to seed arguments in the class about controversial topics, and one being the years of high school (the last four years of mandatory education). He argued that the final two years of high school was useless for some people, and that by the time they got there they had decided that school was not their forte, and had given up. He thought that students should be given an option of going into a trade school instead of grades 11 and 12, or doing those grades and going onto higher education.
