what do I need to get started in Propeller?
basicstampede
Hello.· I have the Pro Development Board (which I use for BS2) along with RS232 cable, power supply for the Pro board.·
I would like to start experimenting with Propeller.
What is else do I need to buy in order to start learing about Propeller?· (I hope the Pro board accepts Propeller).
Thanks in advance.
Thanks in advance.
To get started you need a programmer, such as the prop clip, a propeller chip, eeprom, and a few components. This is the way I experiment with the Prop; I have all the components mounted on a breadboard, and this setup works well for me. This is probably the cheapest way to get started. Check out the sticky posts at the top of the propeller forum, there is a ton of good info there.
You can also buy the Propeller proto board, which can be programmed with the prop clip. I've also used this the only draw back is you need to solder connectors/headers to the I/O pins on the circuit board.
Another option is the propeller demo board, which is programmed with a USB?? cable (I think the cable comes with the board). This board has a lot of experimental components (LEDs, VGA/Mouse/keyboard connectors) already mounted. The only real drawback is a number of the I/O pins are used by the other components on the board.
Either buy or download the propeller manual in the download page from the main Parallex page.
I hope this helps,
Good luck!
(There are two "Getting Started" guides in my .sig below.)
However, you will need to do some soldering to get things to an interesting level.
If you want to skip the soldering, you might look at the Demoboard Kit
which will give you video/VGA/keyboard/mouse/audio connections, but
you will be limited to 8 additional I/O for other experimenting.
If you like KITS, there's always SpinStudio from uController.com which
does require soldering, but has many addon cards and comes complete
with everything except the Propplug.
There's a variety of Propeller options which cover just about every desire
these days. Even a new Propeller Developement Board. A little pricey
compared to a demoboard, but offers a lot of functionality.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
Concentrate on understanding the problem, not applying the tool
Either one of the pre-built boards parallax sells or do it yourself with some components and a soldering iron. You do not need much more than the programmer (is a FT232 plus a transistor) and a propeller chip.
Visit the propeller wiki @ http://propeller.wikispaces.com/ it contains a wealth of information in one accessible place.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/19/2008 5:07:29 PM GMT
~Some men see things as they are and ask "why?"
I dream of things that never were and ask "why not?"~
Promise.
Rich
