There are two versions. One uses the prop plug or prop clip·(which you will need in addition to the Proto Board) for a serial connection. This version is the older version and cost about $20. The newer version is the direct USB connection. It costs about $40.
You can have a lot of fun and learn about the prop with the Proto Board. Olbitcollector's Intro will give you some fun, quick first projects.
Whit+
and by looking at Oldbitcollectors Inroduction to the Propeller Proto Board found here - http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/32212-32812-Protoboard_Introduction.pdf
Whit+
Post Edited (Whit) : 8/17/2008 10:01:45 PM GMT
thanks for the answer. i just did some home work and figured it out.. should have done that before I showed my ignorance LOL
thanks again
Badger
It is the surface mount, 44 pin IC near the middle of the board. See picture at
www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/Level/a/ProductID/423/Default.aspx?SortField=ProductName%2cProductName
(EDIT)
I see others replied while posting above info. (/EDIT)
Harley Shanko
