cell phone batteries — Parallax Forums
LoopyBytelooseLoopyByteloose Posts: 12,537
edited 2008-08-17 17:47 in General Discussion
I just came across my old Nokia cell phone that I have retired for a Samsung.
It has a Lithium cell inside and makes a great recharger. So I put together a board to power an SX-28 with the unregulated output because it is roughly 3.9 volts peak.
My problem is that I really don't understand the Three connector pins on the battery. One nears the corner is + and then I get two that appear to be negative. But between the Plus and the middle pin I get 3.74volts fully charged and between the Plus and the inner most pin I get 3.98volts fully charged.
If I use an LED to indicate output. I get a very bright LED between to Plus and the 3.98v Negative Pin. But I cannot get the LED to light in any combination of the middle pin.
Am I missing something? Is this two cells and one is going bad? Or is the middle pin a 'sense' lead of some sort to prevent excessive discharge of the battery?
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2008-08-16 19:30
    Hi Kramer,
    since you don't need them any more for their first purpose, I'd say, "take 'em to the bandsaw!" and carefully cut them open to see. You can always patch them back together again.
    I'd bet it's a sense line.
    We have a couple of old Nokia's here too actually...
    Sharping my blades,
    Howard
    Buzz Whirr Click Repeat
  • LeonLeon Posts: 7,620
    edited 2008-08-16 21:04
    It's usually connected to a thermistor for monitoring the battery temperature whilst it's charging.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2008-08-16 21:46
    Ah Ha! Nothing like your cell phone melting all over your latest schematic!
    - H
    edited 2008-08-16 22:14
    It's more likely to catch on fire ... very violently and hard to put out.
    edited 2008-08-16 22:24
    Hey Mike,
    sounds like you're speaking from experience... ever had to extinguish a DELL laptop? wink.gif
    - H
  • NR1XNR1X Posts: 111
    edited 2008-08-17 00:12
    gotta love it .. hear LiPO batts are pretty volitile too
    edited 2008-08-17 01:03
    Use care.. Looks like those batteries could mimic a roman candle.. [noparse]:)[/noparse]
    www.youtube.com/watch?v=mlZggVrF9VI
    OBC
    New to the Propeller?
    Getting started with a Propeller Protoboard?
    Check out: Introduction to the Proboard & Propeller Cookbook 1.4
    Got an SD card connected? - PropDOS
  • SRLMSRLM Posts: 5,045
    edited 2008-08-17 03:54
    From the movie, it looks like the camera person expected the laptop to catch fire. They had the camera running before the flame...
    Anyway, a LiPo and LiIon can be damaged by both over charging and draining excessively. The telltale sign is that the battery starts to swell. I considered buying some for a project, but I didn't want to incinerate my BOEs. Plus, they were twice as expensive as a NiMh battery of the same Ah. Anyway, the guys at a model hobby shop (racing cars, helicopters, and planes) seem to know quite a bit about different battery types and what voltages and currents to use.
    Thanks, but no thanks, I will keep this battery intact at least until it no longer charges properly.
    I have had an R/C Lithium cell swell up like a pregnant guppy. I got rid of it immediately as I had visions of the charger going up in a fireball. Since it was a $30USD battery, I was quite annoyed. But, better safe than sorry.
    Apparently, the purpose of the middle contact is indeed for a thermistor or other solid-state thermal sensor. One can use the battery without it being connected.
    In this context, I think I can safely ignore it. The thermistor will be engaged when charging in the old cell phone. And the SX-18 board that it will be used on is not going to make excessively quick drainage of the battery. I am setting up a timer for battery recharge station.
    I am going to use the internal comparator on the SX to limit the discharge to about 3.0 volts. Lithium cells and just about any rechargible battery doesn't like to go below 50% of its rated output. Such deep discharges usually cause damage.
