If so, it looks like you could use a BS2 without much trouble. The voltage is 5 volts, so that is good. The article gives a complete discription of the communication protocol, so it seems like you could just plug and play. Just tell me that you're not using this for nefarious purposes...
The pulses are too short (50usec) to be able to catch them all by monitoring two different input lines. What I would do is stretch the "ones" line pulses to about 100usec using a one-shot. Then feed the output of that, along with the "zeroes" line into a NAND gate. What you'd be looking at on the NAND's output are short (0) and long (1) positive-going pulses 2msec from leading edge to leading edge. PBASIC's PULSIN is your friend here. With some clever programming (left as an exercize for the reader), you should be able to keep up with the data rate. If you want to play it safe, go with the faster Stamps.
According to the reference cited by SRLM, the Wiegand protocol uses two lines: one for zeroes and one for ones. As I stated above, I don't think you'll be successful monitoring two lines with the Stamp, since the pulses are so short. Better to fold them into one, as I illustrated.
OTOH, are you hoping to monitor a raw Wiegand device (i.e. magnetic sensor) output directly? That would be a different story altogether.
That's a two-line protocol, so — again — at the very least, you will need some external hardware if you plan to use a Stamp. In your particular system, what are the actual pulse widths and pulse spacings?
http://en.wikipedia.org/wiki/Wiegand_interface
'Still some PropSTICK Kit bare PCBs left!
TIA.
--christj
--christj
Thanks.
--chris
