BS2sx Menu Routine Using GET And PUT
I created a basic·menu routine using the GET And PUT commands freeing up valuable variable space by using scratchpad RAM.
This program uses the DEBUG window and can be used in any slot that you wish on your BS2sx.
You will need·four buttons to use this menu.
This program was written for the BS2sx and should be used in a slot because of it's size.
Program attached.
How can there be·nothing? Nothing is something!
Post Edited (beazleybub) : 8/16/2008 4:23:37 PM GMT
Program attached.
