help w/ little step-u
Need help on correctly wiring the "Little Step-U".· Am trying to wire the "Little Step-U" board, the "HomeWork Board", stepper motor and power supply as shown in the "application sample" shown on page 11 of the documentation· for "Little Step-U". Have found however, that the programming provided by Parallax called "Simple Stepper Motor Demonstration" as a test for correct set-up calls for "P4-P7 to be outputs.· Also the page 11 schematic shows a connection from "Vin" to "Vss".· What should that look like with the components I am using?· Have tried to ammend the page 11 wiring to reflect the configuration of P4-P7 being outputs.· Currently my wiring is· the black, orange, brown, Yellow wires are connected to the coil A-D pins on the "Little Step-U" and since the programming·has P4-P7 as outputs I've connected the "serial out" pin on the "Little Step-U" in series with P4-P7 on the "HomeWork Board".· Does this sound right? Thanks, PeterR
I'm Replying as you posted this at 09h53 and nobody has Replied.· So, I'm certain the floodgates will open forthwith.
