Portable Prop Developement
Oldbitcollector (Jeff)
I'm always looking for ways to make Prop development more portable.
I just ordered one of these... Should replace the need for a composite screen or audio..
www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=612720&CatId=1428
@Bean: These are perfect for your board..
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
OBC
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ D Rat
Dave Ratcliff· N6YEE
Cheaper then buying a small lcd! Me thinks me get one too!
~Kam (^8*
I'll write up a review when it gets here..
OBC
Baggers.
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
OBC
This really isn't any different than a TV tuner/capture card. I've been using one for a couple months on my desktop with much success. I agree too, there is about a 1-2 second lag between an input on my demolition board and what comes up on screen. The best part with these things is the ability to take screen grabs (or record what's going on) then post them to a forum post for debugging. WAAAYYYY better than taking a picture of your TV screen with a camera!
-Parsko
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
If you use the tv.out, then add to the FDX code a pub fdx.out and use the exact format of the fdx.tx pub and it calls fdx.tx
something like ... (not verified)
PUB out(txchar)
tx:=txchar
Then you only need to change the
OBJ
tv = "tv"
tv = "FullDuplexSerial"
I'm fairly impressed with the unit. Graphics Demo looks pretty good.
(I'll do a capture later) I'm recording at 30fps which is fine for
the reason I purchased.
It does work with VLC player, but I'm still working out the color settings.
Sooner or later I'll nail down the perfect Hue/Saturation settings.
I'm impressed enough to recommend it for Propeller use.
OBC
