Rubber bushings tomount case fan — Parallax Forums
KatyBriKatyBri Posts: 171
edited 2008-08-16 01:13 in General Discussion
Does anyone know where I can buy small rubber bushings to mount a standard 4" case fan, to isolate vibration? Thanks
  • Matthew HMatthew H Posts: 23
    edited 2008-08-15 02:33
    These aren't rubber bushings but they will dampen vibration from a 4" (80mm) case fan. I never bought one of these, but I have shopped at Newegg.com a lot and have found that the customer's product reviews are a pretty accurate indication of the quality of the product.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811999209
    Hope this helps,
    Matthew
    edited 2008-08-15 15:20
    Rubber grommets that are ordinarily used to protect wire that passes through a sheet metal chassis come in all sizes. I suspect they will do just fine.
    Be advised that all rubber or neoprene mounts will wear out over a period of time. The material just ages and gets hard. It doesn't do any good to buy spare parts to keep on hand because they will age too.
    Another alternative is a small 'cone shaped' spring. I've no idea if it would be as quiet in this context, but it would last indefinitely.
    It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
    Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
  • DufferDuffer Posts: 374
    edited 2008-08-15 19:22
    An alternative to just the the rubber grommets are these vibration dampener kits from CyberGuys. 120 mm shown, but links to other sizes available on the page below.
    http://www.cyberguys.com/templates/SearchDetail.asp?productID=4863&curpage=1
    Duffer
  • KatyBriKatyBri Posts: 171
    edited 2008-08-15 22:49
    Ordered what I needed. Thanks everyone!
    edited 2008-08-15 22:56
    What did you get?
    - Stephen
    I ordered these (really neat) - http://www.cyberguys.com/templates/SearchDetail.asp?productID=4863
    They also have a similar product for PC power supplies.
