PS/2 Keyboard - all the same? USB to PS/2?
Still trying to figure out about a keyboard for my project.
I have read another post about the Parallax keyboard not necessarily working on a computer, but what about the other way around. Would it be "safe" to say that any "normal" PS/2 keyboard would work on the Propeller?
What about a keyboard which is USB, can one just use a USB to PS/2 connector, and then everything is fine?
I don't have anything against the Parallax keyboard, but just looking for something even smaller.
Thanks for any suggestions.
Best regards,
David
Best regards,
David
(I believe you need to use a USB keyboard that is explicitly designed to
do this, though; this may be the majority of the keyboards out there, or
a small minority, I don't know.)
Once I tested with a mouse USB (USB to PS/2), but did not work.
I am still in the planning stages of my project, so I don't have all the goodies to test it out yet. So before I go spending a good few bucks on a mini-keyboard, I wanted to double check the collective wisdom of others.
Thanks for the input.
Unless there is some sort of trick to this, it might send me back to the drawing board.
David
The dongles are usually device specific (within reason) and therefore you can't just grab one you had lying around and whack it on a USB keyboard/mouse and expect it to work.
PS2/USB converters on the other hand are generally fully active devices and allow you to plug any PS2 keyboard and/or mouse in and it will interface to a USB port.
I like the suggestion by SRLM where you build a portable thingo with a PS2 connector on it to carry and test. A Proto board with an LCD display would be ideal if it were battery operated.
Pull my finger!
I guess I'll buy the 'official' Parallax keyboard, and then perhaps build a 'portable keyboard tester', and visit some store. No doubt one would get some odd looks [noparse]:)[/noparse]
Thanks for everyone's help.
David
I get them anyways, because I acutally look at the keyboard not for their looks but how comfortable to type they are, and so on
