Scrolling the screen: watching data with the PLX-DAQ and Excel
Howdy,
I'm planning on using a Prop to make measurements and record the data onto an Excel sheet using the PLX-DAQ.
I would like the last row of Excel data (the latest data read) to always be visible on the computer screen.
Anybody out there know how to make that happen? Would it be a command used in spin or something done on the Excel side?
thanks a heap,
Mark
thanks a heap,
Mark
oh there are so many ways to do this
you could do something like this
prop sends out a defined columm with an incremented number
i.e number=2100
I assume the values are between 0 and 999
add a columm that multiplies that number with 10^6 and adds the measured value (i.e. value=847)
result 2.100.000.847
Let's say the results were in columm "C"
put into one cell the function max(C1:C64000)
this catches always the last value
next is a cell substracting the big number
2.100.000.847 - 2.100.000 = 847
i took a short look into the PLX-DAQ.spin-file
this provides several commands sended by the prop to the PLXDAQ to set the excelsheet to a defined cell or to send a message
which will be shown PLX-DAQ control
so start playing with it and you will get it
best regards
Stefan
I don't think using PDAQ.Msg would do me any good because I'd like to be able to look at a long row of data on the Excel spreadsheet, plus the most recent 10 or so rows of data above it. PDAQ.Msg sends a little message to the controller box that "floats" above the Excel sheet during operation.
Your other suggestion still has me in a fog. I'm not a veteran Excel user, so I guess I'll finally have to actually break down and learn how it really works (darnit).
I'm new to the Propeller, too, so you are casting pearls before noobs.
I'm working on it, though.
thanks again,
Mark
i have another idea.
If you receive the data from the prop to a terminalsoftware that can write the received data to a textfile
you will see always the latest data on the screen.
For easy importing the data to excel you simply format the data with TAB or semicolon. Between each string that should be placed in
its own columm in excel send a TAB ($08) or a semicolon or comma. Excel can import CSV-Textfiles (comma-seperated-values)
Here is a terminalsoftware that can log the data to files
best regards
Stefan
