Need Docs/Software for "legacy" Stamps
I was cleaning out my garage and found a box·with a couple·of old Stamps.··The orginal ones that had a 9v battery connector. These have to be about 12-15 years old.·One of them was still wirewrapped to·one of Scott Edwards' backpack LCD controllers. I pluged in a battery and it·started running with what I must have written as a LCD display tester.
I looked over the Parallex website and can not seem to find any documentaion or software for these. I seem to remember that it might have been a DOS program to edit/load the Stamp. It was loaded via a parallel cable. The PIC mpu is marked PBASIC 1.4.
Where can·I find the docs/software for these devices?
Thanks for any help.
Ray
Ray
Since it has a parallel port for programming, it's probably a BS1. You can buy a converter for programming (www.parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/40/List/0/Level/a/ProductID/44/Default.aspx?SortField=ProductName%2cProductName) or build your own from the schematic on this web page or in the PBasic manual.
Post Edited (Mike Green) : 8/13/2008 8:51:01 PM GMT
That board uses the BASIC Stamp 1. The only thing that has changed since then is that you cannot use the DOS editor on modern Windows computers. For this reason programming is done through the serial port now. You may need the BS1 Serial adapter we carry ($4.95) to allow the BS1 to be programmed as the BASIC Stamp 2 is, through the serial port. I hope this helps. Take care.
Ray
