Stepping Motor HELP !
Hi All,
·· I should start by saying I am new to stepping motors. I picked up these stepping motor and have attached the PDF for them. My question is there is 6 wires coming out of the motor, but only 4 are attached to the connector. It seems the 2 commons are not attach to anything and wrapped under the insulation. Can someone explain this to me please?
When you spend 10 times what it cost to build it yourself - That's when it becomes a HOBBY !
- Stephen
Ken
Jim-
Post Edited (kenwtn) : 8/13/2008 10:16:01 PM GMT
Then hook up each of the other lines to the 'outputs' on the ULN2803. When you provide a signal to the ULN2803 input pin, it will switch ON the associated phase coil by grounding it.
Beware - until you get this part all straigntened out, I'd suggest using a seperate power supply for the stepper and the stamp. Back EMF's on steppers can really mess with your life.
Cheers
Jim-
·· I made the connections as suggested and I have attached the code I am using. Now all I get is the stepping motor gittering back and forth. Any IDEAS
- Stephen
A wise man told me; "All electronics are made to work by magic smoke.
Don't ever let it out as it's·very difficult·to get it back in."
