How long does it take to load firmware from flash? possible to speed up?
Just as subject says. Using the $20 prop proto board with the at24c512 flash chip
New to prop. My application requires reasonably fast power-on start-up time (i.e the firmware has to start running within 100-300 milliseconds from power-on). If the startup is slower, is there a way to speed it up? I read in one of threads about speculation to clock the i2c faster (1Mhz?). I would upgrade the eeprom chip if necessary (will have to do it anyway to get into automotive rated temperatures)
tried searching but no luck
Alex
Alex
'Still some PropSTICK Kit bare PCBs left!
Can you perhaps elaborate on your proposed solution? How much faster can i make it?
Is there an application note explaining the process of Prop interacting over the Plug? I can see on schematic it simply uses two other io pins for the plug. Is it possible to control the speed of loading up the firmware from the outside of the prop? (i.e isn't the speed of upload fixed and predetermined internally?)
Thanks again
Alex
The idea would be that the small program would be able to then copy a complete program from the EEPROM to RAM at full I2C speed, then start up a Spin interpreter. I'm not sure how much time this would save. The only other documentation on the bootloading process is the source code of the bootloader which has been posted.
The bootloader protocol and the format of the serial data is designed to work in the absence of an accurate timebase (crystal clock), so it uses a ratiometric scheme which is less efficient than straight asynchronous serial data.
At 1MHz I2C bus speed the full 32KB could be read in around 300ms. Using the program header information at $0004-$000F, it's not necessary to load the full 32KB, only up to start of Stack, in most cases only up to start of Variables and that will be correspondingly quicker for many programs.
Page 18 of the Propeller Manual 1.01 does add some caveats. There's a 100ms delay after power-on to reset. Page 20 shows power-up delay as 10ms, the Propeller Datasheet suggests none but isn't clearly stated so who knows which is right ? There's also an additional 50ms delay period all agree on.
Assuming 100ms power-on plus 50ms delays, 16KB should be loaded and running in around 300ms.
Loading from a traditional bus Eeprom with a counter to do addressing would speed things up. One could even interface the micro itself that way so Propeller Boot Eeprom not even needed.
Post Edited (hippy) : 8/13/2008 9:46:29 PM GMT
Why use I2C, if you have more pins available, why not split it up, and use parallel comms, since parallel tasks is what the prop is all about [noparse]:)[/noparse] or if you have 10, why not go 8bit bus + 2 control bits, then it'd be filled in no time at all [noparse]:)[/noparse]
obviously, you'd have to use phil's idea to send a small boot app, which then reads from more IO's.
Baggers.
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
I will look around the website, but i would really appreciate links to the documents needed to implement this bootloading over the prop plug port
So far i went through the datasheet and the protoboard doc and there was nothing on that
Cheers
Alex
http://forums.parallax.com/showthread.php?p=609066
Also look at "Propeller development for non-Windows users"
