Control Board Via Software
Hi everyone! I'm been reading like crazy the last week or so working on my project but I was hoping someone could point me in the right direction. All the guides I have read have you write a program in PBasic and upload it to the chip but I need to control the chip with software. I'm a C#.NET programmer so anything along the .NET lines would be great! I'm trying to trap events on various servers and then light LEDs in a sequence for each different event. Is there a tutorial out there that can show me how to control the chip through software running on a PC?
I found this thread:
http://forums.parallax.com/forums/default.aspx?f=5&m=284235
but that person if already way past where I am right now. I'm trying to figure out if I need to build a listener server on the chip and then talk to that from my application or if I can just control the chips I/O voltages directly in my application with no software needed on the ship?
Sorry for all the questions,
Thx
Thx
The examples are Visual Basic but you should be able to transpose them over to C# relatively easy. The first example in the thread shows how to send 1 byte of information from a PC to a Stamp. You are going to have to understand PBasic in order to use the information you are sending but this is one building block of many to help you on your way.
Jeff T.
WOW! Thanks, this is perfect. I'll wrap the VB.NET code into a static lib (I think it's called Shared in VB) and it will work just fine for my application. Awesome!
