Electronic Fuse Controlled by a Basic Stamp This Project is almost done
Hi· Every One
I took a·Transformer···from a Low Voltage 12 volt AC Light
Removed the winding for the 12 volt part
I put· 3 pairs of wire Two Turn Each Back on the Transformer
This will work for 5 amp @ 120 volt AC as you can see in the photo below
Then I used a ADC 0831 and a 4N33 Optic Sensor to work with the Basic Stamp
I also have a 2 line Parallax 2 LCD Display that I am using
The Photo is not there yet
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 8/15/2008 2:42:58 AM GMT
··Thanks for any·
·that you may have and all of your time finding them·
Sam
The reason for this Project is because it has a 2 Amp fuse for the Speed Controller for the·Milling Machine Controller·that·I keep blowing so
I though this some thing that a Basic Stamp could do
I have not·written the part for the trip the relay· yet but i have circuity for it working· this will be easy to do
·I have the LCD displaying the amps··
What I want LCD Display is·if I can get it to work the way i want it to work For each charter·I want to use a (*) to show 100 millamps this just an example
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/15/2008 2:36:25 AM GMT
· IF· result = 0 THEN
·· SEROUT LCD, Baud, [noparse][[/noparse] DispLightOFF]
·· SEROUT LCD, Baud, [noparse][[/noparse]LineOne0, "System OFF"]
·· SEROUT LCD, Baud, [noparse][[/noparse]LineTwo6, "System OFF"]
·· ELSE
·· SEROUT LCD, Baud, [noparse][[/noparse]LineOne0, "A· M· P· S"]·······················
····································································· ·· ' create report screen
·· SEROUT LCD, Baud, [noparse][[/noparse]LineOne12,DEC mVolts DIG 3, ".",
····················· DEC3 mVolts]···································· ·' report
· IF IN4 = 0 AND result > 40 THEN
····························································' This for when the System is OK
· SEROUT LCD, Baud, [noparse][[/noparse]LineTwo1,"00 OK· OK·· OK"]
· ELSEIF IN4 = 0 AND result < 40 THEN
·· SEROUT LCD, Baud, [noparse][[/noparse]LineTwo1,"00 T O· S L O W"]
·· SEROUT LCD, Baud, [noparse][[/noparse] DispLightON]
················································· ' This when the Motor is· running to slow
·· ELSE
·· SEROUT LCD, Baud, [noparse][[/noparse]LineTwo1, "* OVER· LOAD *"]
··································································· ' OVER LOAD @ 1.75 Amps
·· SEROUT LCD, Baud, [noparse][[/noparse] DispLightOn]
·· ENDIF
·· ENDIF
I would like to have this on line two instead what I have now
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/17/2008 3:57:45 AM GMT
Wouldn't it be better to find out why the fuse is blowing in the first place?
Thank You For your Reply
I know the reason why the fuse keep blowing is if you try to cut to fast then you will blow the fuse·I want some thing that dose two thing
One I want to see a display when i am going to fast
Two When i have gone way to fast the Basic Stamp Take over and shut down the Milling Machine
By The Basic Stamp taking Over the control before the fuse blows
I just do not have the shut down writen yet maybe i will write it today
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/15/2008 4:49:56 AM GMT
This has been the hardest project that done so far
The biggest problem has been getting the display work right
When I would add the INPUTS 3 and 4 The LCD would not want to work or·just not·come on at all or just freeze
after many hours of working on this project I think I have it working the way i want it
One thing·I found my self doing a lot was using··· laps = laps + 1 and DEBUG DEC5 ? LAPS to see where it was hang· at· BUT very use full routine
It has same file name but is very different
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/17/2008 3:59:02 AM GMT
I found one more problem I had the display working OK· when testing it but as soon as·I put the routine in to control the Power Relay then the Display
was acting up and·So·I went back to using the ADC Demo in Stamp Works again then This Demo would not work right either
It turn out that the resister that i was using with a 2N2222A was to low of a value
I was using a 220 ohm so·I changed it to a 560 ohm resister and now it works a lot better
I am not sure·which one was happing
The Basic Stamp was to draw to much current on that pin·or the Basic Stamp was Resetting it self because of it
The Routine has been changed again because I found that some of what i had before would not work right
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/23/2008 10:13:51 PM GMT
