question re: Oscope
when using a scope to monitor·output activity on a prop, i get, what i believe is ringing·(a short oscillation after a·change of state).· what are the possible causes of this?· is it the scope, the probes or the layout of the circuit?· the circuit is just a resistor and LED.· when i push the speed limit of the scope it really distorts the signal.
- Stephen
Assuming you really have this ringing and not just a scope artifact, it can be caused by a chip's output device. It can also be seen in situations where current on a wire is too high for the output device. Basically ringing is caused AC impedence problems on the little transmission line-oscillator-wire connecting two or more devices.
One way to limit the effect is to put a small resistor in series with the output device and the next device connected. If you have wires with multiple termination points, the ringing can be hard to control and an end of line terminating circuit may be required. Having a 0.01 uf capacitor connected between a chip's power and ground can also help ringing. The best way to limit ringing with all else being normal is to have a good controlled slew-rate driver in your chip output device hardware.
Ringing is mainly a design quality issue. On one hand, it can contribute to extraneous RF emissions ... think buzzing in your PC or car stereo speakers every time a cheap cellphone is in use. On another hand, it can damage the devices in the circuit over time because of overshoot or undershooting voltage limits.
I can only assume from the frequency, this is somehow related to or sourced from the house power.
