Is it true the propeller can only access 8 of it's bits on the propeller board?
Is it true the propeller can only access 8 of it's I/O Ports on the propeller board? I read this somewhere. Or, does it mean the proto board can only access 8 without further circuits added? Do I need a servo card or can I just add a serial resistor to drive the motors on the boebot?
The Protoboard has access to all the Propeller I/O pins although some of them are pre-wired for VGA / Keyboard / Mouse.
However, if you would connect more things that are not TV / Audio Out / Audio In, then you need direct access to the I/O pins and the Proto Board would be ideal.
You can then use the Accessory Kit to attach VGA / Keyboard / Mouse.
