Almost readable photograph using only 64-bit color — Parallax Forums
dnaddordnaddor Posts: 26
edited 2008-08-15 16:51 in Propeller 1
Hi everyone.
I'm toying with the idea of designing a new security product, and I want to use the Prop. There must be a half dozen reasons why this will turn out to be impossible, but I'm really motivated to keep the cost down and using the Propeller is far better than using a PC (like my potential competitors).
The first showstopper is to create a readable photograph using only 64-bit color. I thought about using 4 bits instead of 2 bits per color, but I didn't know how difficult it would be to synchronize multiple cogs, and I didn't want to spin a board to try it. So I explored dithering the existing colors.
I discovered that it isn't necessary to handle each bit separately. I clock 4 bits of the same color horizontally. Because each vertical line is different, dithering compensates.
The attached program generates a photo of me! It probably isn't good enough for a production product, but it is a start, and might actually look better on a tiny LCD display.
I just thought I'd share this with the Parallax community in case it inspires someone.
P.S. Anyone know or want to guess if the Prop II will include more video capability?
  • jazzedjazzed Posts: 11,803
    edited 2008-08-12 01:56
    You could probably get away with even less detail for image recognition software. As it is almost all Propeller memory is used, and that will be a big problem. Good luck.
  • scanlimescanlime Posts: 106
    edited 2008-08-12 02:08
    If memory was the only limitation, and you mostly needed to display stored bitmap graphics, you could try using a compressed framebuffer.
    S3TC/DXTC is a compression algorithm that is very simple and fast to decompress, but it also gets decent compression ratios without a lot of quality loss. It's based on blocks of 4x4 pixels, where each block is represented by a 2bpp bitmap and two 16-bit colors. The 4-color palette consists of the two specified colors (endpoints on a line) as well as two more colors interpolated between the two endpoints. It probably wouldn't be too hard to write a video driver cog which decompresses a DXTC framebuffer in real-time.
    http://en.wikipedia.org/wiki/S3_Texture_Compression
  • BaggersBaggers Posts: 3,019
    edited 2008-08-12 10:28
    Micah, and dnaddor,
    S3TC/DXTC will give you a decent image, 256x192 = will still be 24KB though, and decompression to a scanline renderer will take a good couple of cogs, I only know cos I've done it [noparse]:D[/noparse] the slow part of the decompression is the interpolation between the two specified colours, but you would need more than one prop, as 24KB is a lot of memory, although with it only being 6-bit ( 64 colours not 64-bit ) you could reduce this down further to 18KB, as for creating the image, would it have to be digitized? or is the image just a token display after finding out who it is? ( eg after card swipe etc? ) cos if you're getting it from SD that's gonna need about another 8K ( currently ) for the drivers, if you're digitizin it, not sure how you'd manage that with a prop, it's a bit slow for all those calculations, on a frame, especially for realtime grabs.
    jpg, could be read in, ( some cams send you the stream IIRC ) I've already done a jpg reader to display also with PropGFX, but that wasn't re-encoding it to DXTC it was just to a 128x96 bitmap buffer. I suppose that could be done though, although I'm not sure how fast you'd be able to get the data uncompressed and re-compressed to DXTC.
    good luck with your task though, keep us informed.
    http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
  • RaymanRayman Posts: 16,378
    edited 2008-08-15 14:31
    Very nice! I wonder if you could cover the whole screen by making 4x4 square pixels by repeating each line 4 times...
    Rayman, this image is output by the propeller ( my PropGFX with SCART output ), doing realtime decoding from DXT1, to 15bit RGB.
