Virtual Serial Ports
I am trying to use the com0com and hub4com software to
create a virtual null modem cable to program the scribbler over
a Bluetooth/serial link.· (A physical null modem cable between
the BT/RS232 device and the Scribbler works, but a virtual
null modem cable is easier to wire-up.· The BT/RS232 device
I have does not have a DTE/DCE switch so I need the cable.)
The Scribbler programming software (both the GUI and
the Editor) refuses to recognize the virtual serial port
as a valid com port.· I've tried passing the com port
as an argument to the stampw program, but still no success.
The software does recognize my virtual bluetooth com
port, but not my com0com port.· I'm guessing no one
has tried this setup before, but can someone provide
some hints/guesses as to what might be wrong?
Tony Richardson
Tony Richardson
A null-modem cable should not work or be used in the connection. A standard straight-through serial cable should be used. As for issues with virtual connections, these usually fail due to timing issues with the signals. In a wireless system any corruption of the signal which causes a NAK or resend of the data will fail communication with the BASIC Stamp. Systems that were available in the past used a buffering system to store the code on the target end before actually programming the BASIC Stamp.
Thanks for replying.· I need the null modem because the BT connection I currently have
emulates a null modem cable.· I need a second one to "undo" the·emulated one.
A physical null modem cable between the BT/serial converter and the scribbler works.
(The BT/serial converter and cable ride on the scribbler.)· This setup works.
I was hoping to use a virtual null modem cable on the PC to replace the physical
cable that rides on the scribbler.· This would allow me to plug the BT/serial converter
directly into the scribbler.· Unfortunately, the scribbler software does not detect the
virtual serial port that is created by the virtual null modem.
Tony
because I don't think the software recognizes CNCx as a valid port name.
regards peter
I'll include it below for the form archives.
Tony Richardson
You can "deceive" the robot software this way:
1. With the "Add/Remove Hardware" wizard install new
standard serial port. You don't need a real serial
hardware to do it. Select non conflicted IO/IRQ
resources.
2. With the "Device Manager" disable the newly created
port (let it be COM4).
3. With the "Setup Command Prompt" for com0com install the
pair of ports, were one of them has name COM4. Ignore
warning about the COM4 is "in use" (press Continue).
-Justin Ratliff
The Robotics Club of Yahoo
www.trcy.org
