Cheap hardware for newby + some questions
Hi All,
I have just found out about this wonderful chip and am wanting to try it out on a limited budget.
Some questions:
1. I did see on this forum some PCB's for sale but can't find it any more. Can someone point me to where I can get these? I am particularly
interested in a USB comm/powered version.
2. Where can I get small samples of the chip, do Parallax supply samples or small quantities? If not, can someone point me to a cheap supplier ..
3. My 1st project will involve generating PWM signals, I can't seem to find a basic PWM object in the object exchange, the closest I could find is some motor drivers.
I guess I could hack these to suit, but if there is a basic PWM module, please let me know.
4. Has anyone written state-machine tables in spin or assembly, this requirement is top on my priority list for good coding .....
Thanks to all.
Some questions:
Thanks to all.
Chips can be had directly from Parallax:
www.parallax.com/tabid/142/List/0/CategoryID/18/Level/a/SortField/0/Default.aspx
You may also find these interesting..
www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/Level/a/ProductID/423/Default.aspx?SortField=ProductName%2cProductName
www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/Level/a/ProductID/509/Default.aspx?SortField=ProductName%2cProductName
As for USB-powered, you might be referring to this?
http://forums.parallax.com/showthread.php?p=732252
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
The book with the kit
http://www.parallax.com/Store/Microcontrollers/PropellerProgrammingKits/tabid/144/CategoryID/20/List/0/SortField/0/Level/a/ProductID/382/Default.aspx
Just the book:
http://www.parallax.com/Store/Microcontrollers/PropellerTools/tabid/143/CategoryID/20/List/0/SortField/0/Level/a/ProductID/377/Default.aspx
Useful links. I was actually wanting a source of bare PCB's, someone was selling them, they looked to be in DIP40 module format ..
Cheers,
http://forums.parallax.com/showthread.php?p=729096
Andy
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
that puts a damper on that idea ....I would be quite willing to may for USPS to New Zealand, it should be quite cheap for 4 bare boards ... oh well ..
Brian, I have seen those boards, but what I am after is really a cheaper version of the DLP-PROP ($69), if I can't get that I just might have
to bite the bullet and get one ....
Thanks, anyone have answers to my last two questions?
Parallax doesn't have a sample program like some other chip manufacturers. There are some instances that they have given away samples that I have read about in the forums, but for the most part, I'd say you'll have to buy your Propeller. (most demo boards that were mentioned in this thread include a Propeller)
A cheap supplier, Well, all suppliers that I know of in the USA charge the same as Parallax themselves. I have gotten Propellers from Parallax, Digikey and Mouser.
how about this object ? - obex.parallax.com/objects/216/
Brian
Opps, didn't realize your were outside the US
