Testing for a specific voltage of 220v DC on a remote device
I am using the stamp to trigger a remote device that uses a capacitor that builds up a charge of 220v DC. I want to set a flag that tells me when that device has a fully charged·capacitor. I thought about building a voltage divider that would put a lower voltage to one of the pins, but don't think this is the best method.
·Welcome to the ParaLLAX Forum
BE VERY CAREFUL WORKING·WITH VOLTAGES THIS····· HIGH·AND·WITH··A· CAPACITOR
·Also use a 10 k ohm resister to discharge the capacitor before touching the terminals other wise this could happen to you
This enough to give·you a very BAD SHOCK and this·CAN BURN·YOU if you are not careful
You would need a resister that has a value of 250000 ohms to 125000 ohms this may need to be·ADJ·value depending on when you want it to be trigger but start there
Do this with an LED first you just want the led be light just enough to be seen and no more than that
To get the value of the resistor that is need if you use a green Led the start to light is about 1.7 volts so if you get it there· you will need a little high value resistor to get it to 1.2 volts for the Optic Sensor
Then use optic sensor like any··one of these··· 4N25 , 4N26 , 4N27 , 4N28 , 4N35 , 4N36 , 4N37, H11A1M , H11A2M , H11A3M , H11A4M , H11A5M
···················· This·very important
MAKE VERY SURE THAT YOU DO NOT MORE THAN 1.3 volts at these pins on Pins 1 and Pin 2
Pins (1 +) and (2 - )·are your input this where you will use this value· 250000 ohm resister and hook up to the··capacitor
Use only value that is need to trip the Optic Sensor
250000 = 0.001 amps 1/4 watt····· Try this value first
125000 = 0.002 amps 1/2 watt
83000·· = 0.003 amp 3/4· watt
I would use two·that (= from·125000 to 62500)·one on each pin that way you can measure the voltage at the Optic Sensor pins
Pin 5 will be VDD this 5 volts·
Pin 4 will have a 10k ohm resister and goto VCC
Pin·4 will also have a 220 ohm resister· which will be trigger for your Basic Stamp I/O Pin 0 to 15 just pick one
Then Read this
What’s a Microcontroller?
Chapter #3: Digital Input - Pushbuttons · Page 71
Here is the Link to it
http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Wamv2_2.pdf
In your case you just would not use the switch
·(your switch would be the Optic Sensor)·but every thing else would be the same
code wise
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/12/2008 1:05:32 PM GMT
