Will this work?
Hi there everyone,
I am creating a box to light some matches.
The matches are wound in nicrome wire.
I am wanting a led to light when the fire button is pressed and go out when the wire has broken.
Will this circuit work?
I don't think it will but can't think of an easy way to make it work.
Thank you
Building Blocks To The Propeller Chip A web site designed to help people who are new to the propeller chip.
Guitar Hero controller using the prop (WIP) --> HERE
Thank you
Both ends of the R1-LED1 circuit are always at GND.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
What you really need is a current sensor, wherein the LED lights up when the nichrome wire is drawing current. The attached circuit should do this. You will need to select a value for R such that when the wire is fully incandescent, the voltage drop across R is at least 0.6V. This will cause the transistor to conduct and the LED to light. When the wire breaks, the transistor's base is pulled back to the positive supply, causing it to shut off and the LED to go out. Also, make sure resistor R is rated for the wattage it will be dissipating. You don't want it to become incandescent as well!
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
I have a match, with the tip wrapped in nicrome wire. When current is passed through the wire it heats up and lights the match.
Looks cool.
Thank you
- Stephen
I am using a 12v battery to light the match (probably not necessary but it does the job).
The only regulator I have is an LM1086 5v regulator. I am assuming this would probably still heat up the wire.
The wire I am using is copper wire from a multi stranded wire. So it is really thin. I would guess about 0.2mm - 0.4mm.
I like the idea of the current sensor and the idea of using a low voltage low current to test for a loop.
The only problem I see with the current sensor is that if R is to high a value the wire may not heat up.
Also how would I find the value of R without going through lots of wire and the risk of melting my breadboard?
Thank you
What are peoples thoughts on it?
Thank you
What you have will work and should work good
··Thanks for any·
Sam
When the switch is open, the LED/resistor will conduct through the wire/element.· When the switch closes it presents a short across the LED/resistor.· So, the LED will be on till the switch is closed.
'Still some PropSTICK Kit bare PCBs left!
The switch will only be closed for a short period of time (less than 3 seconds).
Thank you
I just dont know how much resistance is in the heating wire when its red hot, it might be enough to light the LED. Im basing this on how you calculate the resistance of 2 resistors in paralell, but assuming the heating wire would be 0 ohms, at least until it warmed up, then I dont know.
It might be worth testing.
See attached photo.
Chris I.
