Possible ultrasonic range extension?
This is just an observation at this point, so anyone that is interested may want to pursue it. I have one those $20 ultrasonic measuring units bought from the building store. Cool thing about it, is it has a long distance range it can be switched to. Standard range is up to 30 ft. and LD is up to 60 ft. I have tested it, and the LD range works good, although there are errors on objects that are too close. I popped it open to have a look at the circuit, and the LD switch trace looks like it passes though another diode, which is bridged with the first.
If anyone knows how this is accomplished, it would be interesting to know. It operates the same in both modes, sends out 5 pings on both. Anyway, i figured there may be a way to extend the range on the ping sensor with some additional hardware. A 60 ft. range would be a plus to have for outdoor use.
An additional note, the sensor is a single transducer, rather than the transmitter / receiver like the ping, if that makes a difference.
Post Edited (kelvin james) : 8/10/2008 1:15:57 AM GMT
