RS232 tu USB problem NO BASICS STAMPS FOUND
Im trying to write on my BS Homework Board but I cannot acces to it.
When I go to RUN/Identify I get Yes in both Loopback and Echo.
When I go to RUN/RUN I get the error message "NO BASICS STAMPS FOUND."
Im using a RS232 to USB cable on Windows Vista. I already turn of the FIFO BUffer in my computer. (control panel/system/device manager/ports(COM & LTP)/prolific USB-to-Serial Bridge properties)
PLEASE HELP ME!
PLEASE HELP ME!
Typically this is a power problem on the homework board -- is your battery new?
What allanlane5 said. My BOE and eb500 (or eb501) will drain a brand new 9 volt battery very quickly. Additionally, XP SP2 and the Stamp IDE seem to become cross with one another after a time and the only thing that will make them friends again is a reboot. Typical Windows procedure, in other words.
Gee. Vista? I have no clue, but I would certainly make sure the power supply is good and reboot the box whenever the IDE begins acting the least bit weird.
Good luck!
--Bill
You are what you write.
I replace the battery for a new one (you are right, the battery I was using drained out very quickly), however I still have the same problem with a brand new battery.
Thank you for your reply!
I haven't add anything yet. Im using this code to test connectivity
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Test A BS MICROCONTROLLER"
END
Unfortunately I don't have access to a computer with Serial port on board.
Parallax does sell a very reasonable USB to serial adapter guaranteed to work.
