new problem please help for my sci IDE
Ok now that the syntax is working,
Every time I try to load up the program, I get hardware errors and it tells me to check power supply and cable. three is nothing wrong with them that I can see. I even got a blue screen once from this and I rarely get BSODs.
The message about checking the power supply and cable means that the serial connection to the Stamp is not working properly. There are some jumpers built-into the Stamp boards and described in the Stamp Manual. The Editor checks that they're there. The Stamp also echos anything sent from the PC back to the PC as another way to check the connection and the Editor checks for this. Lastly, the download process is an active "conversation" between the PC and the Stamp and the Stamp has to be working (powered) or the Editor will report that there's no Stamp present.
