Help! Some problem with syntax
Every time I try to use the SERIN command problems ensue with the variable with the do while loop or some other Smile happens. here is my code:
I was following the example from: http://www.c-sharpcorner.com/UploadFile/mgold/FlashingStockAlert09152006184241PM/FlashingStockAlert.aspx
Please help. thanks.
' {$STAMP BS2}
' {$PBASIC 2.5}
T9600 CON 84
Inverted CON $4000
Baud9600 CON T9600 + Inverted
letter VAR Byte
SERIN 16, Baud9600,letter ,
counter VAR Byte
DO
SELECT letter
CASE "0"
LOW 5
FOR counter = 0 TO 127
PULSOUT 6, 1
PAUSE 1
NEXT
CASE "L"
LOW 5
FOR counter = 0 TO 10
PULSOUT 6, 1
NEXT
CASE "H"
HIGH 5
PULSOUT 6, 1
NEXT
CASE "1"
HIGH 15
CASE "2"
HIGH 14
CASE "4"
HIGH 13
CASE "8"
HIGH 12
CASE "a"
LOW 15
CASE "b"
LOW 14
CASE "c"
LOW 13
CASE "d"
LOW 12
CASE "n"
HIGH 0
CASE "f"
LOW 0
ENDSELECT
LOOP
The easiest way around this is to put a space after the opening square bracket. Do read the chapter in the PBasic Manual on the SERIN
statement. What you've written doesn't make sense for a simple SERIN statement even with the forum software's behavior.
It's also helpful for you to include only the code that illustrates the problem plus whatever support routines are called. In your case, the
long SELECT / CASE statement isn't necessary and just adds bulk to the posting. What problem are you having?
Adrian
