BS2 voltage
just a quick beginner question.....
when i connect a resisto between the Vdd and the Vss and check the voltage across that resistor using a multimeter, I get a pefect 4.98 ~ 5.00 volts
However, when I connect the resister between a BS2 pin and the Vss and measure the voltage (while sending a HIGH signal), I only get 3.17 volts.......... isnt supposed to be 5 volts as well??????
