stepper motor wiring to Little Step-U
I'm trying to correctly wire a stepper motor to the "Unipolar Stepper motor controller". Have retrieved the data sheets from the Parallax site. The motor that is referenced on the data sheet "(#27964)" is this the same motor as the "PM4222-09" which is scribed on the side of the motor I'm working on? The data sheet drawing shows 5 wires coming out of the motor which is the same as the number coming out of PM4222-09 and also has the same wire colors as the "Mitsumi". If these are the same motors my problem comes in terms of wiring the common (red) wire. The "Unipolar Stepper motor controller" data sheet on page 11 appears to show 6 wires , one for "ct BD" and one for "ct AC" originating from the motor. Where does the common wire need to be wired?
Thanks, PeterR
Thanks, PeterR
CT-AC and CT-BD are tied together with link "LK" on the Little Step-U. I just dug mine out of the dust to play with some steppers i found under some other dust.
The Little Step-U's are great stepper motor controllers.
So........ connect the common to either CT pin. If you need some starter code let me know.
Aaron
If your little stepper motor quivers, then you and I have the same issue. I connected my Step Motor PM4222-09 ( purchased from Parallax) to the outputs of a ULN2003A integrated circuit has directed from the Parallax PDF "Unipolar Stepper Motor (#27964)" instruction information. This somatic FrontPage 2 is pretty rough but when connected in this configuration using the supplied basic stamp to application programming demo "code" all I get is a corresponding quivering to the different portions of the code.
I wonder if there is a difference between the Parallax (PM4222-09) and the (#27964) ???
Rick
