Pullup/pulldown resistors
I'm wondering if the propeller chip has internal pullup (or pulldown) resistors built in, or if unused inputs are just left floating?
Can't seem to find anything definitive on the data sheet.
If no internal terminations, what's the recommended treatment for unused inputs? Most CMOS logic families call for unused
inputs to be terminated with high-value resistors, but with all the pins on the propeller chip, this could eat up a lot of circuit
board real estate.
Larry C.
board real estate.
Larry C.
'Still some PropSTICK Kit bare PCBs left!
letting CMOS inputs float in the "no man's land" between logic 1 and logic 0, as this can introduce a boat load of
noise into the system and excessive power dissipation, leading to potential chip failure in time.
(The project I'm working on requires that the board with the Propeller chip be able to be disconnected from the
rest of the system, thus leaving the inputs open -- so I can't just make everything an output.)
Any thoughts on this?
Larry C.
For thru-hole boards, bussed SIP resistor arrays fill the bill:
Note that SMD arrays of discrete resistors are way less expensive than the bussed variety.
Post Edited (Phil Pilgrim (PhiPi)) : 8/7/2008 9:17:41 PM GMT
Larry C.
I have not seen anything in the Propeller documentation about tying unused inputs.
Paul Baker
Thanks!
John
Inigo Montoya: Let me 'splain. (pause)
Inigo Montoya: No, there is too much. Let me sum up.
The Princess Bride (1987)
Paul Baker
