Tcs230 db to basic stamp homework bs2
i have tcs230-db color sensor and i also have a basic stamp homework board bs2 how do i connect the sensor to the board
i dont have any cable i conected wires to j2
so is it possible to use homework board and how can i connect the board to the sensor
is there any other components that i should buy to make the thing works
please help .. im really new to basic stamp
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol4/col/nv98.pdf
This is for the plain TCS230. The documentation for the TCS230-DB (www.parallax.com/Portals/0/Downloads/docs/prod/acc/TCS230-db_doc.pdf) discusses an extension cable (www.parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/50/List/0/Level/a/ProductID/426/Default.aspx?SortField=ProductName%2cProductName) and adapter (www.parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/50/List/0/Level/a/ProductID/433/Default.aspx?SortField=ProductName%2cProductName) that plugs into the TCS230-DB on one end and plugs into the HomeWork Board's breadboard on the other end where you can run jumper wires to the appropriate Stamp and power connections.
Post Edited (Mike Green) : 8/7/2008 7:01:39 PM GMT
