voltage questions
Hello
i have a motor here rated at 1.2 volts at 300 mh .. how do i cut the voltage down to run this motor on a home work board (i am very new to this) any help would be appreciated
Phil king
Phil king
Do you want battery power supply or wall wart that plugs in to mains?
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
i am using the bs2 stamp i think it is either 5v or 3.3 volt i want to be able power this motor from the bs2 i guess is what i am trying to say
Badger
Badger
so the homework board can not supply this current in a native circuit with what comes with the kit..
Badger
Typically though you should have a separate power supply for your motors so you don't draw too much power from the stamps main supply, that can cause brownouts or dirty power supply that can cause problems with input pins. A typical rechargable battery 9V has only 120mAh and 50mA draw is a big percentage of its rated output maximum.
This motor is very small but given the rechargable 9V specs above you are pushing your luck using the VIN supply. You could use a rechargable AA battery directly and control the power using a transistor of fet as a rechargable AA battery is about 1.2V and 1200 millamp hours is typical so your motor could run for about 4 hours at 100% power on one battery. If you need more time you can use more batteries in parallel. Be sure to connect the two power sources ground lines so you have a common ground or your transistor or fet will not work.
Post Edited (Mike Green) : 8/6/2008 1:11:59 AM GMT
Yes, you're correct.
i just have one more question what is a fet LOL
Badger
i am going to be looking into this method i have a battery pack for 2 aa bateries
FET = Field Effect Transistor
newbies cant live with them and cant grow with out them hehehe
i should have thought of that i am a disabled but was a network engineer for 15 years and such... i will do that..
i am starting back to college this fall to take electrical engineering classes. so i am trying to start early and learn what i can on my own .
thanks for your help very much
Philip King
but here is a good question... What size of fet do i get
Phil
if i dont use rechargable batteries to i still need a regulator or is the regulator the piece that keeps the current or voltage constant to my motor
phil
sorry about the last question reread the post...
Phil
Hope this provides some perspective...
For example, the IRF510 is a nice power FET sold at RadioShack, but it won't conduct much current at a 4-5V gate voltage. The IRL510 is a nearly identical power FET that fully switches on at 5V.
Badger
badger
newbie
badger
http://parts.digikey.com/1/parts/1019473-mosfet-n-ch-100v-14a-220-5-irc530pbf.html
··Thanks for any·
Sam
