cm8880 need help !!!
hi all, new here and pretty new to the stamp also.. iv been tryin to play a little with dtmf for remote control applications via amateur radio, trouble is i cant get the thing to work!!! tried my own programs and those in app kit!! could anyone point me to a good explination of how this thing works.... should i be pulsing the system clock pin on the cm8880. reading the datasheet has only served to further confuse me.. i get the cra/crb but dont know if my data is getting there....
- Stephen
For "SYMBOL x = <constant>" use "x CON <constant>"
For "SYMBOL y = b#" (where # is a digit) use "y VAR byte"
For "SYMBOL z = w#" (where # is a digit) use "z VAR word"
There are a couple of other syntax differences for SERIN / SEROUT / LOOKDOWN / LOOKUP, maybe some others as well.
Dave
Dave Andreae
