expanding pins I/O with a 4099BE ?
mobile_bob
has anyone had any experience using this chip for the purposes of expansion of a bs2's I/O?
i have an I/O board that uses two of these chips to address two banks of 8 output ssr's
i would like to hear if anyone else has used this chip, and maybe what the outcome was
any special concerns, maybe a circuit example
thanks
bob g
thanks
bob g
i was hoping that someone here would have run across its use at least.
bob g
thanks for pointing that out!
that would explain its use on this board where it is used to drive a 4049 hex inverter chip, which in turn drives the ssr's.
they might use this low value component as a failsafe, to burn out and not allow somesort of backfeed to be send back the the
cpu i suppose.
i guess i gotta learn to read the spec sheets more closely, huh?
thanks
bob g
Yes, do read the datasheets.· That's what I do.· They're readily available via the internet.
