reading serial data from my car
i want to continuously read this data and display it·with the the PST terminal and i dont know how.
······················· DATA STREAM A6··· SPECIFICATION
······ SPECIFICATIONS FOR· DATA STREAM INFORMATION
······ ENGINE· USAGES:
············· 5.0l V8 CLCC (LV2) - (Y) - 84
············· 5.0l V8 CLCC (L69) - (G) - 84
············· 5.0l V8 CLCC (LG4) - (H) - 84
············· 5.0l V8 CLCC (LG8) - (9) - 84
············· 5.0l V8 CLCC (LM1) - (6) - 84
······ DATA PIN· : READ DATA ON PIN "D" OF ALDL CONNECTOR
······ BAUD RATE : 160 BAUD
······ MODES···· : DIAGNOSTIC ENABLE:
···················· 10K . . . . . . . YES - 20 WORDS
···················· NORMAL· . . . . . NO
···················· SHORTED . . . . . YES - 20 WORDS
······ DEFINITION: DATA STREAMS CONTAIN THE SAME INFORMATION
·················· IN THE SAME FORMAT WITH 20 WORD FORMAT.
..PAGE
· DATA STREAM DEFINITION
··· WHERE "WORD" IS THE BYTE OF DATA STREAM AS IT IS READ FROM THE VEHICLE
··· AND "BIT" IS THE BIT OF THE BYTE, WHERE 0 IS THE LEAST SIGNIFICANT BIT.
··· WORD· BIT·· DESCRIPTION
··· 1·········· PROMID BYTE 1
··· 2·········· PROMID BYTE 2
··· 3·········· BATTERY VOLTAGE
··· 4·········· COOLANT TEMPERATURE
··· 5·········· VEHICLE SPEED
··· 6·········· MANIFOLD ABSOLUTE PRESSURE
··· 7·········· MODE WORD 1
··········· 0·· ADVANCE FLAG··························· 0 = ADVANCE
··········· 1·· WARM FLAG······························ 1 = WARM
··········· 2·· TIMING ERROR - 100 MSEC LOGIC FAILED TO COMPLETE
··········· 3·· HOT ENGINE MODE························ 1 = HOT ENGINE
··········· 4·· TCC ROAD SPEED 1ST PULSE FLAG
··········· 5·· REAR VACUUM BREAK SOLENOID ON·········· 1 = SOLENOID ON
··········· 6·· EST ENABLED FLAG
··········· 7·· ENGINE RUNNING FLAG···················· 1 = RUNNING
··· 8·········· THROTTLE POSITION SENSOR
··· 9·········· OXYGEN SENSOR
··· 10········· MIXTURE CONTROL SOLENOID DUTY CYCLE
··· 11········· MALFUNCTION FLAG WORD 1
··········· 0·· C24 VEHICLE SPEED SENSOR
··········· 1·· C23 AIR FUEL SOLENOID
··········· 2······ NOT USED
··········· 3·· C21 THROTTLE POSITION SENSOR
··········· 4·· C15 COOLANT SENSOR LOW TEMPERATURE
··········· 5·· C14 COOLANT SENSOR HIGH TEMPERATURE
··········· 6·· C13 OXYGEN SENSOR OPEN
··········· 7·· C12 NO REFERENCE PULSES (ENGINE NOT RUNNING)
··· 12········· MALFUNCTION FLAG WORD 2
··········· 0·· C42 EST MONITOR ERROR
··········· 1·· C41 TAC INPUT ERROR
··········· 3·· C34 PRESSURE SENSOR
··········· 4······ NOT USED
··········· 5·· C32 BARO SENSOR LOW
··········· 6······ NOT USED
··········· 7······ NOT USED
··· 13········· MALFUNCTION FLAG WORD 3
··········· 0······ NOT USED
··········· 1·· C54 CARB. MIXTURE CONTROL SOLENOID
··········· 3······ NOT USED
··········· 4·· C51 PROM ERROR
··········· 5·· C45 OXYGEN SENSOR RICH
··········· 6·· C44 OXYGEN SENSOR LEAN
..PAGE
· DATA STREAM DEFINITION CON'T
··· 14········· CLCC MODE WORD
··········· 0·· BLENDED ENRICHMENT FLAG················ 1 = BLENDED
··········· 1·· COLD START····························· 1 = COLD START
··········· 2·· IDLE LOAD CONTROL WIDE OPEN THROTTLE··· 1 = WOT
··········· 3·· WIDE OPEN THROTTLE····················· 1 = WOT
··········· 4·· NOT USED
··········· 5·· O2 RICH/LEAN FLAG······················ 1 = RICH
··········· 6·· NONVOLATILE MEMORY BOMBED·············· 1 = BOMBED
··········· 7·· CLOSED LOOP FLAG······················· 1 = CLOSED LOOP
··· 15········· I/O STATUS WORD 1
··········· 0·· NOT USED
··········· 1·· NOT USED
··········· 2·· REAR VACUUM BREAK······················ 1 = ON
··········· 3·· TCC···································· 1 = ON
··········· 5·· HIGH GEAR SWITCH······················· 0 = 4TH GEAR
··········· 6·· LOW/MID GEAR SWITCH···················· 0 = 3RD GEAR
··········· 7·· E-CELL INPUT··························· 0 = TIMED OUT
··· 16········· I/O STATUS WORD 2
··········· 0·· AIR DIVERT SOLENOID···················· 1 = SOLENOID ON
··········· 1·· AIR SWITCH SOLENOID···················· 1 = SOLENOID ON
··········· 2·· NOT USED
··········· 3·· IDLE LOAD CONTROL SOLENOID············· 1 = ON
··········· 5·· P/N SWITCH····························· 1 = PARK OR NEUTRAL
··········· 6·· AIR CONDITIONING······················· 1 = A/C ON
··········· 7·· AIR/FUEL SOLENOID TEST················· 1 = SOLENOID ON
··· 17········· MODE WORD
··········· 0·· AIR CONDITIONING SWITCH ON············· 1 = ON
··········· 1·· MOUNTAIN COAST MODE ON················· 1 = ON
··········· 2·· STACK OVERRIDE ON RAM FLAG············· 1 = OVERRIDE
··········· 3·· ESC MALF 43 DISABLE···················· 1 = DISABLE
··········· 4·· EGR ON SOLENOID OFF···················· 1 = ON
··········· 5·· ESC DELAY FLAG························· 1 = ENABLE
··········· 6·· WARM· FLAG····························· 1 = WARM
··········· 7·· AIR CONDITIONING CLUTCH RELAY ON······· 1 = ON
··· 18········· ENGINE RPM
··· 19········· BAROMETRIC PRESSURE
··· 20········· TOTAL CROSSOVER COUNTS
..PAGE
······· CONVERSION FOR A/D COUNTS TO ENGINEERING UNITS
··············· N = A/D COUNTS
·············· EU = ENGINEERING UNITS
······························································· ENGINEERING
··· WORD·· DESCRIPTION···················· CONVERSION············ UNITS
··· 1····· PROMID BYTE 1······················· NONE
··· 2····· PROMID BYTE 2······················· NONE
··· 3····· BATTERY VOLTAGE····················· EU = N*.1········· VOLTS
··· 4····· COOLANT TEMPERATURE················· TABLE LOOKUP
··· 5····· VEHICLE SPEED······················· NONE
··· 6····· MANIFOLD ABSOLUTE PRESSURE·········· EU = N * .0196···· VOLTS
··· 7····· MODE WORD 1························· NONE
³·· 8····· THROTTLE POSITION SENSOR············ EU = N* .0196····· VOLTS
··· 9····· OXYGEN SENSOR······················· EU = N*(4.3403)··· MILLIVOLTS
··· 10···· MIXTURE CONTROL SOLENOID DUTY CYCLE· EU = N/2.56······· % DUTY CYCLE
··············································· EU = 60*N/256····· DEGREES
··· 11···· MALFUNCTION FLAG WORD 1············· NONE
··· 12···· MALFUNCTION FLAG WORD 2············· NONE
··· 13···· MALFUNCTION FLAG WORD 3············· NONE
··· 14···· CLCC MODE WORD······················ NONE
··· 15···· I/O STATUS WORD 1··················· NONE
··· 16···· I/O STATUS WORD 2··················· NONE
··· 17···· MODE WORD··························· NONE
··· 18···· ENGINE RPM·························· EU = N*25············ RPM
··· 19···· BAROMETRIC PRESSURE················· EU = N * .0196······ VOLTS
··· 20···· ALDL RICH LEAN CHANGE COUNTER······· SEE **
·** : THIS IS A ROLLOVER COUNTER (0 - 255), TAKE CURRENT DATA STREAM READING
····· SUBTRACT LAST DATA STREAM READING = CROSSCOUNTS.· IF CURRENT READING
····· MINUS LAST READING IS < 0, THEN TAKE CURRENT READING + 255 - LAST
····· READING = CROSSCOUNTS
..PAGE
······· COOLANT TERMPERATURE CONVERSION
······· DEGREES CELSIUS·········· A/D COUNTS
············ -15···················· 252
············· -5···················· 249
·············· 5···················· 244
············· 15···················· 237
············· 25···················· 228
············· 35···················· 215
············· 45···················· 198
············· 55···················· 179
············· 65···················· 158
············· 75···················· 136
············· 85···················· 115
············· 95···················· 95
············ 100···················· 86
············ 105···················· 78
············ 110···················· 70
············ 115···················· 63
············ 120···················· 57
..PAGE
..PAGE
..PAGE
..PAGE
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
Channel: #propeller
·side? sorry for the stupidity but·i have never really done much·with zeners
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
The striped end of the zener (cathode)·is the positive end, where on a normal diode it's the negative end.
An opto-isolated link would be my preference.
I found this article that gives some detail on a circuit to convert voltages.
http://www.techedge.com.au/vehicle/aldl160/160serial.htm
This should help. I think this would be a really cool project using a uOLED-128 or even the uOLED-96 as a display of what is happening. You could make it switch screens to display the different parameters and the error codes too!
·- Was it pin 11 or 26?· Hmmm....··I think the smell of smoke tells the whole story.· Must be 26.
Michael King
Application Engineer
R&D
Digital Technology Group
