Conditional Compile — Parallax Forums
Conditional Compile
John CoutureJohn Couture Posts: 370
edited 2008-08-03 20:24 in General Discussion
Wasn't there, at one time, a "conditional compile" command that would allow you to indicate to the compiler to compile this block of code (and thus take up memory) if a constant were set otherwise compile this other block of code.
The application is setting up a program that uses an SX18 processor and a SX28 processor with either a custom PCB or the Prof Dev Board (or any combination thereof).· It has to do with assigning ports to specific functions.
I'm using IDE 3.2.3, SXB 1.51.03
John J. Couture
San Diego Miramar College
  • Sens-a-DatSens-a-Dat Posts: 44
    edited 2008-08-03 16:52
    John,
    Here is what I found tucked away in the "What's New?" of the SX/B Help file (found under the Welcome area).
    ' Example of Conditional Compiling Directives
    '{$DEFINE USE_RB} ' Remove this line to use RC
    '{$IFDEF USE_RB}
    LEDS PIN RB
    '{$ELSE}
    LEDS PIN RC
    '{$ENDIF}
    /Gary
  • John CoutureJohn Couture Posts: 370
    That's it! Thank you!
    John J. Couture
