RCTIME on the BS2 Board of education question
hey i am haveing trouble with my circuit and program for basic stamp 2 on the board of education.
i am trying to make a led turn on when a wire is removed from a switch, using RCTIME.
I was told to use a 10 k ohm end of line resister on my switch, and a 0.1 uf cap between my switch on the board of education and vss.
Heres the code im using:
time1 VAR Word
DO
HIGH 3
RCTIME 3,1, time1
IF time1 = 0 THEN GOTO LED
LED:
DO
HIGH 12
LOOP
'End of Code'
But if i use the code below and replace the 0 with one, and activate the switch, the led turns on. Any ideas?
time1 VAR Word
DO
HIGH 3
RCTIME 3,1, time1
IF time1 = 1 THEN GOTO LED
LED:
DO
HIGH 12
LOOP
'End of Code'
Chris.
time1 VAR Word
DO
HIGH 3
RCTIME 3,1, time1
LED:
DO
HIGH 12
LOOP
'End of Code'
time1 VAR Word
DO
HIGH 3
RCTIME 3,1, time1
LED:
DO
HIGH 12
LOOP
'End of Code'
Chris.
State is a variable/constant/expression (0 - 1) that specifies the desired state to measure. Once Pin is not in State, the command ends and stores the result in Variable.
- Stephen
1. switch open / wire intact
2. switch closed / wire intact
3. wire not intact
this will provide the information you need to create the if/then statements.
I found out my circuit was wired wrong.
Thanks for all the advice anyways,
Chris.
