Driving LEDs at 1.4A, 10-500Hz
Hi all,
For all my projects up until now, I've used a ULN2308 for powering things. My current project uses big flashy LEDs that draw much more power than I'm used to, and I'm a bit stumped. Pardon the clear newbishness here, but what should I use to deliver 1.4A at frequencies ranging from 5-500Hz, possibly higher?
Thanks for any pointers. Learning links appreciated!
Blammo
Blammo
Nuts and Volts Column #6 discusses the use of transistors to control high current loads and the Industrial Control tutorial has a chapter on this.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I'm trying to build a 3 LED (R,G and
Blammo
Leon
Trying searching for "Buck Puck".· That is a brand of module I have used in the past for driving higher wattage LEDs.· The modules vary in price, but can be from US$12 to US$20 if I remember correctly.· Maybe this is too costly for your project, but an option I thought I would throw out.
Here is one link, but there are similar products from others.· http://www.ledsupply.com/buckpuck.php
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
Now, say you try to drive a high power LED that draws 350mA at 3.3 volts with a regulated 5 volt power supply.· A 5 ohm resistor will limit the current to 340mA but the power draw from the resistor will be a whopping 1.7 watts.· I've done it before with five 1 ohm, half watt resistors in series but it's a pain.· I wouldn't even consider it for 1.4 amp LEDs.
The Buck Pucks are much easier.· Also, many of them have a "control" pin that will accept a PWM input for dimming.
If you want to design your own, National Semiconductor has some schematics and component calculators to fit the schematic to your particular system.· I highly recommend watching the "Analog by Design" web TV shows about driving high power LEDs·on the National site http://www.national.com/nationaltv/.· They're informative and I found them very entertaining as well.
Chris I.
