Newbie having trouble setting up port communication
I just got a HomeWork board and I'm excited about starting on projects! I have it hooked up to a MacBook Duo and I have the Basic software running on Windows XP on Parallels. I bought the USB->serial cable and hooked everything up, but it doesn't recognize the port. I tried the troubleshooting in the manual but haven't been successful. Has anyone set this up on a Macbook under Windows XP?
Thanks in advance for any suggestions!
Paolo
Paolo
Try that and see if it works
Daniel
When I start the BS2 sw it doesn't recognize any port, even if I enter them manually as COM0 or higher, but the LED light on the USB hub on the cable lights up green when I plug it in.
I also tried downloading the BS2 sw for Mac and it installed fine, runs, but again doesn't recognize the HomeWork board. Could it be that I have to install a driver for the Mac? If so, could you let me know if and where I can find one?
Thanks for helping me out and looking forward to your suggestions, best wishes,
Paolo
The driver MUST match the USB adapter -- download it from the VENDOR'S website (not Parallax) if it's anything other than an FTDI adapter.
If you're using a USB hub, it probably should be a POWERED USB hub. The "unpowered" USB hubs don't support full speed USB connections -- I'm not sure this is an issue, however.
