IR control of Boe-Bot
I am working with IR control of a Boe-Bot using a TV remote control. I have wired·the··Boe-Bot as shown in the manual for "IR Remote for the Boe-Bot" and everything works fine. Now I·want to wire up two IR detectors in parallel, one facing forward and one facing to the rear. This should give better detection of the remote signal, from front or rear.
My question is·can just I wire up the two detector·in parallel·or do I need to put diodes in the circuit to keep one from back feeding through·other. Some where on the Forum I remember a post talking about putting sensors in parallel needing diodes. But now I can not find that post.
Can anyone help?
······ Joe Fishback
-Robots are my friends-
Can anyone help?
······ Joe Fishback
But the best way to find out would be to try it, I suppose.
-Stephanie
