True 640x480@60Hz
I am attempting to drive a VGA LCD display (a·Datalux 8794-01/7D-18005)·with a propeller chip, and running into some trouble. The display in question works only at 640x480@60Hz. I have verified that the display works by connecting it to a computer. I know the propeller video generator works, because it runs all of the video generator demos without any problems (when connected to a more flexible monitor, of course).
Modifying the VGA_text (which runs at [url=mailto:512x480@60Hz]512x480@60Hz[/url]) code sample, I tried:
These settings did not work. I'm looking for the settings to run the VGA.spin driver at a true [url=mailto:640x480@60Hz]640x480@60Hz[/url], or some documentation on how the VGA.spin driver uses the various values and what exactly they mean so that I can work out what I need on my own.
Thanks!
- h front porch =·16
- h synch pulse = 96
- h back porch = 48
- v front porch = 10
- v synch pulse = 2
- v back porch = 33
Thanks!
http://forums.parallax.com/showthread.php?p=725697
http://forums.parallax.com/showthread.php?p=630051
http://forums.parallax.com/showthread.php?p=735992
http://forums.parallax.com/showthread.php?p=658972
and there is this object in the object exchange: http://obex.parallax.com/objects/86/
I don't know if any of the efforts specifically come out to a 60Hz refresh rate, but you should be able to swap out the crystal with one which will drive the screen @ 60Hz (calculate the fps generated, and new crystal value should be = (60Hz/Measured frame rate)*5MHz, it may require using a programmable oscillator if the necessary frequency is a non-standard value.
VGA.spin has a commented section at the end of the file that explains the parameters.
Paul Baker
