serial lcd 2X16 (#27977) — Parallax Forums
stefstef Posts: 173
edited 2008-07-29 22:07 in General Discussion
Hi
Is thier a large difference in hardware between a BPI-216 and an Parallax serial LCD type #27977. I have several sx running on the BPI-216 display using a max233 without any problem. Now I try to convert the program (sx/B) to work with the 27977 but I get nothing on the display. So I was wondering if the 27977 can also work with a max233. In the manual they mention nothing about that.
Has someone experiance with the display 27977 conected true a max233 on a sx (sx/b programm)
Stef
    edited 2008-07-29 15:40
    Here's an SX/B demo for the Parallax LCD that should be helpful.
  • stefstef Posts: 173
    edited 2008-07-29 21:45
    Hi
    Thanks for the example. Now the LCD is running fine on 9600 baud. If I change the settings and the dip to 2400 it is not functioning. I don't know wy but it is not a problem. I'll leave it on 9600 baud.
    Thanks again.
    stef
    There's a constant in the program that sets the baud rate. If you can use it at 9600 (or 19.2), why would you want to use 2400?
