VGA Demo.spin V1.0 unstable horizontal image
Hello all,
Before I get to my question, let me introduce myself. My name is Shawn and I am a EE student from Oklahoma. All four years of my microcontroller experience comes from playing around with Microchip PICs. I just receintly decided to step up from my beloved PIC to something a little more powerful and my search ended when I found the Propeller. The concept is quite interesting and I look forward to experimenting heavily with my new Starter Kit.
Moving on, like I said I just purchased the Propeller starter kit and when it arrived on Sat. I would have sworn it was Christmas. Being eager to play with my new "toy" I promptly connected everything to my computer and started playing with the demo programs that came with the software just to check out the hardware and make sure everything arrived in one piece. So far, everything has worked EXCEPT for VGA_Demo.spin (v1.0 according to the documentation). It compiles and loads fine, but when it runs my monitor repeatedly flashes the image briefly and then horizontally scrolls to black almost like a PowerPoint transition. To me this suggests horizontal sync issues, especially since the vertical sync is perfectly fine. The demo board will run all the other provided VGA demo programs just fine so I don't think it is a hardware problem (at least with the Propeller) but since I've only been "Spinning" since Saturday, I don't yet have a firm grasp on the language to debug this program. In fact, I was excited when I got the "Hello World" LED blinking on my own. Thus, I'm coming to the experts. What do you think, is this a problem with the code or is my demo board defective? Since school is currently not in session, I don't have access to an O'scope right now, otherwise I'd tell you if there was jitter on the horizontal sync signal. (In fact, one of the projects I have in mind for the Propeller is to build a Scope for personal use.)
Thanks in advance,
Shawn
Thanks in advance,
Shawn
It has been said that some LCD monitors may not work properly; can you try a different monitor?
Good luck.
Thanks for the advice,
Shawn
However, I find now that neither the shipping example nor the objex version work.
Anyone know a fix?
CRT displays will display whatever you throw at them.
Paul Baker
"CRT displays will display whatever you throw at them."
That's what I thought at first too except I am using a CRT monitor and it still will not display the demo correctly. In fact, I do not even own a LCD monitor to try it out on. I agree that this is probably something to do with the driver and an inconsistant timing problem because the image will appear on screen for a brief moment (just long enough for you to be able to recognise the image) and then it scrolls off screen to the left in a manner resembling the blurred motion lines behind a racecar in a cartoon. It repeats this same process the entire time you have the Propeller running. Once I get versed in Spin and the Propeller, I will sit down and look at this more closely. It should make for an interesting first project.
Shawn
Paul Baker
Try this change (down in dat section's vgaparams):
······················· long··· 420· '380············ 'vd·
that drops it to 64 Hz...
Yes, this is the only supplied VGA demo that does not work. The Bitmap demo and both the standard and hi-res text demos work flawlessly. As do the tile driver demos. In a PM, Beau Schwabe recommended changing the #vertical pixels to 352 instead of 384 and change the pixel rate clock to 30MHz instead of 35MHz. Once I get a little practice with the Propeller, I will make these changes and post the results. Right now, I'm still mesmurized by my blinking LED [noparse]:)[/noparse]
@Rayman
I made the change and it had no effect on the results.
Thanks guys!
Shawn
