Stamp program stops working
I built my first project on the BOE board and everything worked fine. I transferred over to a super carrier, soldered everything in and had things working until I hooked up the board that holds the 4 595's that run the 36 leds. As I noted prior to moving to the super carrier everything including the led setup worked fine.
Now after the leds come on the stamp program stops running.
I apologize for this is bare bones description but I thought if anyone has a moment to help me correct the problem I could provide the information needed since I am uncertain as to what is needed to debug this thing.
When you spend 10 times what it cost to build it yourself - That's when it becomes a HOBBY !
Thanks for the reply.
Here is my program:
' {$STAMP BS2} ' {$PBASIC 2.5} ' ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- ' ---(motor)--- Phase VAR OUTD 'phase control outputs pins 12-15 ' ---(74hc595)--- Clock CON 0 'shift clock (74HC595.11) DataOut CON 1 'serial data out (74HC595.14) Latch CON 2 'output latch (74HC595.12) ' --------[noparse][[/noparse] Constants ]------------------------------------------------------- #SELECT $STAMP #CASE BS2, BS2E Trigger CON 5 'trigger pulse = 10 uS Scale CON $200 'raw x 2.00 = uS #CASE BS2SX, BS2P, BS2PX Trigger CON 13 Scale CON $0CD 'raw x 0.80 = uS #CASE BS2PE Trigger CON 5 Scale CON $1E1 'raw x 1.88 = uS #ENDSELECT RawToIn CON 889 '1 / 73.746 (with **) RawToCm CON 2257 '1 / 29.034 (with **) IsHigh CON 1 'for PULSOUT IsLow CON 0 ' --------[noparse][[/noparse] variables ]---------------------------------------------------- counter VAR Byte 'loop delay counter garageDoor VAR Bit 'garage door position passes VAR Byte 'number of pauses passesB4sound VAR Nib 'how many pauses before setting off sound soundFired VAR Bit 'sound event detectHold VAR Word 'pause time amt rndmVal VAR Word 'for main loop delay countfrom VAR Byte 'num secs in main loop delay houseLight VAR Bit 'led at door to house ' ---(PING)--- pingDetect VAR Bit rawDist VAR Word 'raw measurement inches VAR Word ' ---(motor)--- idx VAR Word 'loop counter stpIdx VAR Nib 'step pointer stpDelay VAR Byte 'delay for speed control rotationAmt VAR Word 'rotation amount ' ---(74hc595)--- pattern VAR Byte 'output pattern ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- Steps DATA %0101, %1001, %1010, %0110 ' --------[noparse][[/noparse] init ]--------------------------------------------------------- GarageLed PIN 3 Ping PIN 5 HouseLed PIN 8 'sound trigger PIN 4 'sound return PIN 7 passesB4sound = 2 'number of hold times before sound is heard soundFired = 0 detectHold = 20000 'hold time pingDetect = 0 rndmVal = 39778 'init random value houseLight = 0 ' ---(motor)--- Setup: DIRD = %1111 'make P12..P15 outputs stpDelay = 35 'set step delay (rotation speed) rotationAmt = 280 'set rotation amount ' ---(74hc595)-- Initialize: LOW Latch ' --------[noparse][[/noparse] main ]---------------------------------------------------------- HIGH GarageLed DO DEBUG CRSRXY, 2, 15, CLREOL, "Checking PING ", "pingDetect is ", DEC1 pingDetect GOSUB Get_Sonar 'get sensor value inches = rawDist ** RawToIn 'convert to inches DEBUG CRSRXY, 2, 16, CLREOL, "distance is ", DEC2 inches IF (inches < 16) THEN 'must be less than 16 inches to begin cycle pingDetect = 1 ENDIF PAUSE 4000 'pause 4 seconds IF (pingDetect = 1) THEN DEBUG CLS, CRSRXY, 2, 1, "PING under 16" PAUSE 4000 'pause 4 seconds DO DEBUG CRSRXY, 2, 15, CLREOL, "detection LOOP checking PING ", "pingDetect is ", DEC1 pingDetect GOSUB Get_Sonar 'check if person still there inches = rawDist ** RawToIn DEBUG CRSRXY, 2, 16, CLREOL, "distance is ", DEC2 inches IF (inches < 12) THEN 'must be less than 12 inches to proceed DEBUG CRSRXY, 2, 3, "PING under 12" PAUSE 2000 GOSUB Get_Sonar 'one more check inches = rawDist ** RawToIn DEBUG CRSRXY, 2, 16, CLREOL, "distance is ", DEC2 inches IF (inches < 12 AND garageDoor = 0) THEN DEBUG CRSRXY, 2, 4, "person there, garage closed" LOW GarageLed GOSUB OpenGarageDoor PAUSE 2000 pattern = %11111111 GOSUB FlipLights 'turn on lights soundFired = 0 passes = 0 FOR counter = 30 TO 0 DEBUG CRSRXY, 2, 30, CLREOL, DEC2 counter PAUSE 1000 NEXT counter = 0 ELSEIF (inches < 12 AND garageDoor = 1) THEN DEBUG CRSRXY, 2, 4, CLREOL, "PING under 12, garage open" DEBUG CRSRXY, 2, 5, CLREOL, "passes are ", DEC1 passes DEBUG CRSRXY, 2, 6, CLREOL IF (passes > passesB4sound AND soundFired = 0) THEN DEBUG CRSRXY, 2, 6, CLREOL, "sound is fired" HIGH HouseLed houseLight = 1 PAUSE 2000 GOSUB RunSound 'turn on sound soundFired = 1 ENDIF passes = passes + 1 ENDIF ELSEIF (garageDoor = 1) THEN DEBUG CRSRXY, 2, 3, "person gone, close garage" DEBUG CRSRXY, 2, 4, CLREOL DEBUG CRSRXY, 2, 5, CLREOL DEBUG CRSRXY, 2, 6, CLREOL IF (houseLight = 1) THEN LOW HouseLed houseLight = 0 ENDIF pattern = %00000000 GOSUB FlipLights 'turn off lights GOSUB CloseGarageDoor FOR counter = 60 TO 0 DEBUG CRSRXY, 2, 30, DEC2 counter PAUSE 1000 NEXT counter = 0 pingDetect = 0 EXIT ELSE DEBUG CRSRXY, 2, 3, CLREOL, "PING over 12, person gone" pingDetect = 0 EXIT ENDIF DEBUG CRSRXY, 2, 9, CLREOL, "pause in detection loop" ' hold time before checking PING distance again FOR counter = 20 TO 0 ' pause 20 seconds before checking PING distance DEBUG CRSRXY, 2, 30, DEC2 counter PAUSE 1000 NEXT counter = 0 LOOP ELSE DEBUG CLS, CRSRXY, 2, 1, "PING over 16" ENDIF DEBUG CRSRXY, 2, 9, CLREOL, "pause main loop" RANDOM rndmVal countfrom = (rndmVal // 8 + 2) * 10 FOR counter = countfrom TO 0 'Wait random # Seconds before checking PING DEBUG CRSRXY, 2, 30, CLREOL, DEC2 counter PAUSE 1000 'Display Counter Every Second NEXT counter = 0 LOOP ' --------[noparse][[/noparse] subs ]--------------------------------------------------------- Get_Sonar: Ping = IsLow 'make trigger 0-1-0 PULSOUT Ping, Trigger 'activate sensor PULSIN Ping, IsHigh, rawDist 'measure echo pulse rawDist = rawDist */ Scale 'convert to uS rawDist = rawDist / 2 'remove return trip RETURN OpenGarageDoor: PAUSE 3000 DEBUG CRSRXY, 2, 6, CLREOL, "open garage door" FOR idx = 1 TO rotationAmt 'controls how much rotation GOSUB Step_Fwd 'rotate clockwise NEXT garageDoor = 1 RETURN CloseGarageDoor: PAUSE 1000 FOR idx = 1 TO rotationAmt 'controls how much rotation GOSUB Step_Rev 'rotate counter-clockwise NEXT garageDoor = 0 inches = 0 'reset inches to zero PAUSE 4000 'pause 4 secs before turning light back on HIGH GarageLed RETURN FlipLights: SHIFTOUT DataOut, Clock, MSBFIRST, [noparse][[/noparse]pattern] 'send pattern to 74x595 SHIFTOUT DataOut, Clock, MSBFIRST, [noparse][[/noparse]pattern] 'send pattern to 2nd 74x595 SHIFTOUT DataOut, Clock, MSBFIRST, [noparse][[/noparse]pattern] '3rd SHIFTOUT DataOut, Clock, MSBFIRST, [noparse][[/noparse]pattern] '4th PULSOUT Latch, 5 'latch outputs RETURN RunSound: SEROUT 4, 84, [noparse][[/noparse]"VSV $00", CR] 'set volume full in hex SEROUT 4, 84, [noparse][[/noparse]"VPF gSnd01.mp3", CR] 'Play sound file PAUSE 2000 'pause 2 secs RETURN ' Turn stepper clockwise one full step (7.5 degrees) Step_Fwd: stpIdx = stpIdx + 1 // 4 'point to next step GOTO Do_Step ' Turn stepper counter-clockwise one full step (7.5 degrees) Step_Rev: stpIdx = stpIdx + 3 // 4 'point to previous step GOTO Do_Step ' Read new step data and output to pins Do_Step: READ (Steps + stpIdx), Phase 'output new phase data PAUSE stpDelay 'pause between steps RETURN
How much current DO those LED's take? How many of them are on at the same time? And how are you powering your board?
The board is powered by the wart that came with the super carrier board - 1000ma.
Would the BOE transfer power different than soldered board, since I did not see this behavior before?
How might I go about trouble shooting a current draining problem?
Can this be rectified by using a higher amperage wart?
Post Edited (gchrt) : 7/30/2008 6:41:40 AM GMT
